Richard Allen Crook
Question: Do you white balance after you are dialed into the desired scene file or do you white balance at the stock "zero" setting and then dial in the scene file?
For example: Let's say I'm dialed into a scene file that provides the look desired, like a warmer look where the picture is slightly orange. When I white balance, is seems to totally counter the warmer temperature settings therefore diminishing the look.
Should I just stop worrying about color and shoot with stock settings, and do all correction in post?
