Okay, so I was just reading through Barry's book for, like, the umpteenth time and I just noticed something. On pages 100 and 101, the book says that by setting the DV Control to EXT (external), you can connect a DVX to another, cheaper MiniDV camcorder via the Firewire connectors on both cameras and the DVX will control the cheap camcorder as an external recording deck with NO LOSS OF QUALITY AND AT THE SAME FRAME RATE THE DVX IS RECORDING! At the same time, the DVX is not using its own internal tape drive! Just think, you can do all the filming you want and never wear out the DVX's heads. You can use a cheap camcorder for all your recording and capturing without a tape even being in the DVX but the output on the tape is the same!
Or, you can set the DV Control to both and both cameras will record for automatic backup tapes.
