Saving Default Scene Settings to a SD Card?
Shooter
Please advise me on how one saves the Default Scene Settings to a SD Card.
I am trying to re open then in a PC as text files and print them out.
In the SCENE FILE menu you should see a command that says "CARD WRITE". This will give you the option of selecting which card you'd like to write the scene files to. Write the files, pop out the card, write-protect it, and pop it in a card reader and you should see the SCENE.TXT file inside one of the card directory folders.
Did all that and darned if I can see the Scene Settings in the User txt file!
Must be doing something wrong.
Interesting…
On my card, there's a file labeled "SCENE1.TXT" hidden deep in the PRIVATE>MEIGROUP>PAVCN>SBG>P2SD folder.
No worries, Shooter. Glad to help.
Keep in mind that the data in the .TXT file will not correspond exactly to the settings you see on the AF-100. What I mean is, a Master Pedestal of -3 in the camera might read as -70 or something like that in the .TXT file. I haven't quite figured out exactly how the numbers relate to each other, but this is something you may notice.
Heres what they look like here: ALl Default
Ver 1.00-00
AG-AF102EN
SYSTEM FREQ:50Hz
TITLE:DITLE1
<F1>
SCENE NAME: ; NAME EDIT
00003001: 0 ; OPERATION TYPE
00003002: 9 ; REC FORMAT
00003003: 0 ; VFR MODE
00003004: 50 ; FRAME RATE
00003005: 0 ; DETAIL LEVEL
00003006: 0 ; V DETAIL LEVEL
00003007: 0 ; DETAIL CORING
00003008: 0 ; CHROMA LEVEL
00003009: 0 ; CHROMA PHASE
0000300a: 0 ; COLOR TEMP Ach
0000300b: 0 ; COLOR TEMP Bch
0000300c: 0 ; MASTER PED
0000300d: 0 ; A IRIS LEVEL
0000300e: 0 ; DRS
0000300f: 6 ; GAMMA
00003010: 0 ; KNEE
00003011: 0 ; MATRIX
00003012: 0 ; SKIN TONE DTL
00003013: 0 ; B/W MODE
00003014: 1499 ; SYNCRO SCAN
00003015: 360 ; SYNCRO SCAN (ANGLE)
<F2>
SCENE NAME:FLUO. ; NAME EDIT
00003001: 1 ; OPERATION TYPE
00003002: 8 ; REC FORMAT
00003004: 25 ; FRAME RATE
0000300e: 0 ; DRS
0000300f: 0 ; GAMMA
00003010: 0 ; KNEE
00003011: 2 ; MATRIX
<F3>
SCENE NAME:SPARK ; NAME EDIT
00003005: 4 ; DETAIL LEVEL
00003007: 4 ; DETAIL CORING
00003008: 3 ; CHROMA LEVEL
0000300c: 18 ; MASTER PED
0000300e: 0 ; DRS
0000300f: 4 ; GAMMA
00003010: 0 ; KNEE
<F4>
SCENE NAME:B-STR ; NAME EDIT
0000300e: 0 ; DRS
0000300f: 3 ; GAMMA
00003010: 0 ; KNEE
<F5>
SCENE NAME:CINE V ; NAME EDIT
00003008: 10 ; CHROMA LEVEL
0000300e: 0 ; DRS
0000300f: 6 ; GAMMA
00003010: 0 ; KNEE
00003011: 3 ; MATRIX
<F6>
SCENE NAME:CINE D ; NAME EDIT
0000300e: 0 ; DRS
0000300f: 5 ; GAMMA
00003010: 0 ; KNEE
