Saturated, colorful pictures?
Depending on what "look" you're wanting, it can be very easy. For instance, if you want the entire film to be "warm" or "cool", just white-balance with a warm or cool card. Costs...nothing.
Or if you want punchy colors, mess with the settings a bit. Also free.
Dan
Dan
GenJerDan: by "card" do you mean a filter glass piece?
Dan
GenJerDan: Punchy colors is one thing, but If the light bouncing off of a blue object (lake water for instance) reflects along with it too much of the white light inherent to light itself, then that light will be picked up as that much more reduced in its "vividness" right? This polarized white light is going to be exponentionally greater than the "punchiness" you can "dial-in" as a setting I would think.
I'm going to have to experiment with this.
Just trying to keep from having to spend tons of money on Chrosziel's masterpiece in order to be able to use poloarizers with my anamorphic.
Most of the "warm card" functionality can be accomplished in-camera. After you manually white-balance, if you want the image warmer or cooler, just adjust the Color Temp scene file setting...
