I conducted this measurement several months ago with the help of users on dpreview. I'm posting it here now to make it official. Feel free to use the measurement in your chart of readout speeds Samuel H.
User Usee filmed the test. The shot was taken on a tripod and involved smooth consistent speed panning from right to left, with vertical lines extending from the top to the bottom of the image. In other words: perfect for an accurate measurement.
User hootsmon transcoded the video and uploaded it here: https://drive.google.com/file/d/0BzSCb-RC8txOZTQtVlUyTGw1b0E/view?pli=1
The first image shows a single frame in which the skew is measured.
The second image shows the same frame but with a cutout from the following frame overlayed in the bottom right hand corner. This shows the location of the slanted line one frame later. As you can see, in the cutout the line has the same slant showing that the panning speed is consistent.
The green line shows the amount of skew of the vertical line across the entire height of the frame. The orange line shows the distance traveled by the line in one frame. The actual measurement in mm or whatever doesn't matter, It is the ratio between these two lengths that we are looking for. So I zoomed as closely as possible to get the greatest accuracy. I found that the ratio is 0.75 or 75%
Since we know that the frame rate is 24fps, we know that the time in milliseconds represented by the orange line is 1000/24 which is 41.666. We know that the green line is 75% of the orange line so the time represented by the green line is 41.666 * 0.75 which is 31.25. So this is the approximate readout time in milliseconds for DCI 4k mode.
Its worth noting because both DCI 4k and UHD modes use the entire sensor width, that UHD actually uses more of the sensor vertically. 1.0666 times as much. The readout time in UHD mode will therefore be 1.066 times as much. Which is 33.33 milliseconds.
So
DCI 4k = 31.25ms readout
UHD = 33.33ms readout.
Usee did provide a 1080p clip but I was away when he posted it and the link is no longer valid.
However, this video compares 1080p rolling shutter to the A7s and also NX1 4k. 1080p is good. 4k is bad: https://www.youtube.com/watch?v=fxWPHkxDE5k
So
