[FS: General] Sachtler Hot Pod Tripod & Panorama 100mm Fluid Head
zijital
sold
Used, needs a little TLC, but very functional.
Head is a Sachtler Panorama 3+3 (I believe). Three levels of pan & tilt drag, plus "0." Pans & tilts very smooth. Locks are very tight. Just missing pan arm (something I usually don't use, and I often take it off because it gets in the way. I can provide links to find an affordable replacement to the winning bidder if desired). Includes quick release plate (standard 1/4" & 3/8" screws included, but not pictured). Counter balance works like a charm.
Hot Pod - one leg moves perfect, the other two stick some, don't fall free & just need to be pushed some to extend / contract. I don't see any bends or dents in the legs, so might be a simple fix to get back to normal. Even with the extra effort, this tripod is still "the fastest in the world." Post doesn't close all the way & one of the rubber feet needs to be replaced.
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_1.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_2.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_3.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_4.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_5.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_6.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_7.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_8.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_9.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_10.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_11.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_12.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_13.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_14.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_15.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_16.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_17.jpg
http://img.photobucket.com/albums/v703/zlove/sachtler_hotpod_100mm_panorama_18.jpg
