djmfoxtrot
The Sachtler FSB-6 / 2 MD Aluminum Tripod System offers stable movements to deliver the best images possible. The FSB-6 system consists of the FSB-6 fluid head with Sideload Plate S camera plate, ENG 75/2 D 2-stage aluminum tripod, mid-level spreader and case.
Frictionless Leak Proof Fluid Damping Frictionless leak-proof fluid damping with three levels of drag, for perfect pictures while panning, without jerks and vibrations. Identical across both horizontal and vertical planes, and allows complete disengagement of drag for fast panning.
Snap and Go The FSB-6 head accepts a payload from 1 to 6 kg while using Sachtler's Snap & Go sideload mechanism.
Dynamic Counterbalancing System The dynamic counterbalancing system compensates for torques as the camera tilts, preventing the camera from inadvertently tipping, and ensuring that it is positioned securely at any tilt angle.
Safe at any Temperature Operates without any friction from -40°F to +140°F.
Load Capacity: 13.2 lbs
Mount Base: 75mm 3" Half Ball
Balance Plate: Yes, Fixed
Pan & Tilt Range: 360˚ / +90˚ -70˚
Pan & Tilt Drag: 3 Steps +0
Leveling Bubble/Illuminated: Yes / No
Material: Aluminum
Leg Stages/Sections: 2/3
Minimum Height: 30.3 in
Maximum Height: 63"
Folded Length: 33.1"
Weight: 11.5 lbs
Retails at B&H for $1,827 Now at auction on eBay
(http://www.ebay.com/itm/Sachtler-FS...s-/191374849653?ssPageName=ADME:L:LCA:US:1123)
Reviews : http://www.bhphotovideo.com/c/product/498210-REG/Sachtler_0473_FSB_6_2_MD.html
I purchased this spectacular tripod new at B&H and have used it with great care. Never dropped, never abused in any way. No dents or bent components.
It works perfectly and is in great condition. Bid with confidence that this is a world class video tripod system. The head and sticks are at auction together and will not be separated.
I am also selling my Sachtler Dolly 75 which is a perfect complement to this great tripod. Please check my other listing on eBay.
For sale and shipment only within the continental United States.
Material: Aluminum
Maximum Height: 63"
Weight: 11.5 lbs
