Hello, for sale is a Sachtler FSB 10 Fluid Head w/ Sideload Mechanism + Extra Sachtler Plate
$1499
FREE Expedited Shipping to US.
I also have the item for sale on Ebay with the same Title.
It was purchased brand new a few months ago and saw very light use in a studio-only setting.
As a result, it remains in Like-New/Mint Condition.
Smooth as butter, utterly perfect pans and tilts, living up to the Sachtler name.
The Fluid Head remains unregistered and is free to be registered in your name and address for the Extended Warranty
Included:
- Sachtler FSB 10 Fluid Head w/ Sideload Mechanism
- FSB 10 Pan Handle
- Sachtler Tie Down Knob for 100mm Halfball Clamping Bowl
- Sachtler Sideload Plate (S/Ace Tripod QR Plate for FSB 10, FSB 8, FSB 6, FSB 4, FSB 2, DV-1 Fluid Heads)
- Extra Identical Sachtler Sideload Plate (S/Ace Tripod QR Plate for FSB 10, FSB 8, FSB 6, FSB 4, FSB 2, DV-1 Fluid Heads)
- 2 Mounting Screws per plate
- 2 Extra Plate Screws Mounted Underneath the Head
- Sachtler FSB 10 Fluid Head Original Manual
If you have any questions, please feel free to ask.
PRODUCT HIGHLIGHTS
- 8.8 to 26.5 Pounds Payload Range
- 100mm Half Ball
- +90 to -75º Tilt Range
- 10 Stepped Counterbalance
- Pan and Tilt Drag 5 Grades Plus 0
- 4.7" Sliding Balance Plate
- L/R Pan Handle Rosettes
- lluminated Bubble Level
The FSB 10 Fluid Head from Sachtler supports payloads up to 26.5 lb. Designed to accommodate digital cinema-style cameras, such as the Sony FS7, Canon C500, and Blackmagic Ursa Mini. The head offers Sachtler's Sideload mechanism with a sliding range of 4.7". It also features a 10-step counterbalance along with horizontal and vertical 5-step drag controls. In addition, a zero setting on the pan and tilt drag controls allows for unencumbered movement of the head.
The fluid head features a 100mm bowl interface for tripod mounting and incorporates an illuminated bubble level for easy leveling in poor light conditions. A pan handle, which can be mounted on either side of the head, is also included.
Leveling Ball with Flat Base
The fluid head features a 100mm ball for quick leveling on your tripod legs. The ball features a flat base so you can also mount it on a flat surface.
Frictionless Leak-Proof Fluid Damping
Frictionless leak-proof fluid damping with five levels of drag enable precision adjustment to match the needs of your shot. A zero setting allows complete disengagement of drag for fast panning.
Camera Mounting and Balancing
Featuring a sideload mechanism with a sliding range of 4.7" that offers the ease of a touch and go quick release plate and the balancing capability of a sliding baseplate. This sideload setup allows for up to 4.7" of balance plate travel.
Load Capacity 8.8 to 26.5 lb (4 to 12 kg)
Diameter/Thread 100 mm
Counter Balance System Spring-loaded (Stepped counterbalance mechanism)
Counter Balance Range 10 steps
Center of Gravity Maximum payload has been measured at 100 mm
Quick Release/Wedge Plate Sideload camera plate S
Balance Plate Not Specified by the Manufacturer
Tilt Drag 5 steps, plus zero
Tilt Range +90° to -75°
Tilt Lock Yes
Pan Range 360°
Pan Lock Yes
Leveling Bubble/Illuminated Yes/Yes (battery powered)
Battery CR2032 3 V battery for illuminated bubble level (included)
Pan Bar DV 75 single pan bar (included)
Diameter: 0.63" (16 mm) / 1" (28 mm)
Length: 16.9" (430 mm)
Temperature Range -40 to 140°F (-40 to 60°C)
Height 7" (178 mm)
Weight 5.9 lb (2.7 kg)
$1499
Included:
- FSB 10 Pan Handle
PRODUCT HIGHLIGHTS
- 100mm Half Ball
Tilt Lock Yes
Pan Range 360°
Pan Lock Yes
Height 7" (178 mm)
