jmvdigital
Sachtler DV 6 SB fluid head paired with the Sachtler Speedlock 2-stage carbon fiber legs. Less than 5 months old. Features a 75mm bowl, 20lbs. payload capacity, lightup bubble level, mid-level spreader, steel spike feet with additional rubber flat feet for hard surface. Comes with their plush padded zip-up bag. Super steady, barely used.
I machined a small hole in top sliding plate to allow it to be mounted to slide forward and backward while still allowing access to the safety bolt. Functions exactly as it does stock, except now you can reverse the plate to compensate for overly rear-balanced cameras like the Sony EX1. I had to do it, otherwise the head would always creep because the balance couldn't be achieved perfectly, now it's more flexible.
The exact specs: http://www.sachtler.us/index.php?id=1109&exp_mode=product&exp_pid=334&exp_cid=109
Sells for $2150 retail, asking $1700.
Also have a Sony EX1 and Matrox MXO up for sale.
PM me or write me at info (at@) jmvdigital.com
-Justin
-Justin
