[FS: Support] Sachtler DV 6 Fluid Head Tripod System.
jmnpro
SOLD.
Great condition, serviced, works perfectly. Includes Sachtler DV6 with 75mm ball head plus Sachtler aluminum tripod, mid-level spreader, new pan bar, and plate with mounting screws. Unmatched Sachtler quality.
Code No.: 0610
Weight: 5 kg / 11 lb (excl. cover)
Max. load: cameras up to 6 kg / 13 lb
Balance Plate: 60 mm / 2.4" sliding range
Grades of drag: 5 each horizontal and vertical, 0
Tilt range: +90°, -75°
Tripod fitting: 75 mm ball
Height range: 79 to 154 cm / 31.1 to 60.7 in (upper edge of head)
Pan bar: 30mm diameter ribbed rosette pattern (pan bar #0992)
Congrats on the sale. Just out of interest, is there some advantage to removing the pricing info that was available on the original description? When I’m researching a product this is valuable info to help understand the market...
