F3: S-LOG on F3 and other issues..URGENT HELP!!
Hi all,
Rented an F3 which has version 1.45 installed on it.
I can not select the S-LOG function currently, any help on activating it? Shooting tomorrow and need help activating it!
I have a Atomos Samurai attached to it as well, which I wanted to record the S-LOG RAW files to. Which settings do I chose for that, currently I can only choose: 1.5G YPBPR422 & Video
Do I need both SDI cables in HD-SDI A & B or can I use just A?
Any help would be great! thanks!
*You'd probably get a quicker response if this had been posted in the F3/5/55 general section, rather then in "Screen grabs/footage".
If the camera does not have the paid RGB S-Log that you would activate in the video out where you see the "1.5G YPBPR422 & Video" option, then you need to go to the Picture Profiles and select S-Log there. You can use just SDI-A, that prevents a menu overlay accidently getting put on top if you use the video out SDI. On the Samurai go to timecode and select Sony SDI trigger.
Remember, middle gray with S-Log is at 38 IRE, not 50. Use the camera spot meter marker in the viewfinder/LCD setting.
