thefilmaddict
So I am learning how to use our FS7. I want to do a test shoot using S-Log 3 to get the most dynamic range. I don't have an external monitor with waveform or a waveform monitor to set exposure. In a run and gun situation, when you only have a tripod and the camera and no Gray Card, what's the simplest way to get proper (or close to) exposure?
Here's what I was thinking (I could be totally wrong):
1. Put the camera in Cine EI shooting mode/color space SGamu3c
2. Record 3840 24p XAVC-I
3. Make sure Gamma is S-Log 3
4. Make sure the LCD monitor LUT is set to Pl:709 (800%)
5. Don't let the whites go over 90 percent zebra using a standard white piece of paper placed in the scene???
In edit, the footage will look like log (not what I saw on the LCD screen), but it should look normal when I drop a s-log 3 LUT on it (I currently own the impulz luts for s-log 3).
Sound good? Should the zebra be set to something else? Should I use the internal waveform instead?
Also, I noticed that all of the white balance settings are in preset mode and they would not allow me to set a manual white balance. Do you not have to white balance in s-log 3 mode (that sounds wrong to me)?
Thanks a million!
Thanks a million!
