RX100 IV initial impressions
Haha, well not much else to say yet.
I'm shooting 1080p120 routinely, but not much with the HFR settings. As I said before, 240p is nearly as good as 120p, just a bit softer, but still very close. I'm not using it because 120p is continuous recording, whereas 240p is burst-only, and takes some time to write to the card.
I'd only use 480p if I really, really needed it. For a specific clip where it won't cut with anything else, or where a single shot can be graded completely different to mask the IQ difference. (e.g. on a comedy short, you can use this 480p for an awesome slap, then grade this single shot very aggressively to hide how much softer and noisier it is).
Regarding color, I'm sticking to my Flaat settings, then adding an instance of Colorista II at the end of my pipeline to desaturare highlights.
Things I'll check in the next week or two: rolling shutter at different resolution and fps modes, and image stabilization settings.
come on samuel, i am following this thread with excitement, you left us waiting for 2 whole days lol
Any 500fps shots ? I see and read everywhere that it is very ugly.
What - am I chopped liver? :) I posted a 480fps clip earlier.
Let me know what you'd like to see - I'll use Samuels Flaat settings and do some hfr shots for you. It's a fun little camera to play with so I would be happy to help out :)
Let me know what you'd like to see :)
Lol sorry is saw your videos earlier and watched it just now again, just forgot it was in this thread ( i watch too much stuff right now lol ) . Your 480 fps seem to be good enough and i think you can pimp it up a bit to look sharper.
A shot with some fruits thrown i a bowl of milk would give a good indication of how able the resolution of 240/480 fps is to produce a pleasant image ( keeeping the milk cold helps it look better ) People's shots always work good too. Thanks if you have the time.
Phillip bloom has done something like that and messed up his kitchen, but the shots are ...well kinda bad in their setup. https://vimeo.com/132989951
There are ways to incrase the slowmo effect in post, so i'm wondering if 120 fps or 240 fps gives you enough room to increase slowmo effect and get acceptable footage ?
Normally i wouldn't be in a hurry, but There is some guy who wants to sell his rx10 IV and this makes me itchy to buy it from him and wanna make a decision . Here in Euroland we get ripped off it costs new 1700$. I do prefer the rx100, because of the size, but if the price is really good, i could live with having its big brother.
Decided i really need to rent it myself to see what it's like.
I already said before that the maximum aperture goes to f/2.8 quite fast. Well, this is how fast it goes (taken from this):
I said "IIRC by around 40mm-equivalent it's already f/2.8", and it turns out it's even sooner, by around 32mm you're already at f/2.8 max
Can I offer a little suggestion for clarity--the time-honored way to describe frame rate is with "fps" as in , 240 fps, 120 fps etc. True, there has developed a nomenclature of describing standard frame rates as 24p, 30p etc. but that has never been used above 60 and once you get to the higher numbers, it starts to become confused with resolution. When I see 480p, I think of standard def resolution in the drop-down menu on Youtube, or the once-state-of-the-art EDTV plasma in my bedroom that maxes at 480p...gotta replace that dinosaur!
Regardless, I have been reading about your adventures with interest as I am an RX100IV owner who has done shamefully little with this marvelous camera other than take it on location scouts and to the odd social event. Please keep posting!
^ Good point. I'll stick to 1080p60 because it's shorter but from 120 onwards it does look weird. Plus, everything is p now, I won't consider anything i anymore.
Location scouts and social events is what I want this camera for, in the long run: two years from now I expect to have a much better camera for serious stuff, but I expect this little toy to still be useful just because of how small and convenient it is.
New stuff:
Rolling shutter test: it's very good in 1080p, and pretty bad in 4K
15.4 ms in 1080p24
34.2 ms in 4K 24fps
In both cases, add 1ms if image stabilization is set to standard instead of off (which for me means "basically always", see below).
Look here for a comparison with other cameras.
4K:
Now that I shot my first two clips in 4K mode, for testing RS:
- 4K introduces an extra crop of approximatel 1.1x
- 4K has a lot more detail when looked at 100% (and also a bit more noise)
- 4K-to-1080p is significantly sharper than internal 1080p
- 4K-to-1080p-reframed is still significantly sharper than internal 1080p (e.g. 4K scaled to 62%, or 57%, or 53%)
Stabilization (I only tested in 1080p mode)
The RX100 IV doesn't have IBIS but it does have electronic stabilization.
In 1080p24 it doesn't lose any sharpness when turning stabilization on, in any of its modes. RS does get slightly worse (around 1ms worse) but you're unlikely to notice because it's pretty good anyway and no-microjitters helps a more than this 1ms.
Steadyshot standard doesn't add extra cropping: the lens remains a 24-70mm f/4.9-7.6 FF-equivalent in terms of FoV and DoF.
It's quite effective to get rid of micro-jitters. I'm very happy with this mode.
Steadyshot active adds an extra 1.18x crop, bringing it to a total of 3.2x, which means the lens becomes a 28-82mm f/5.7-8.9 FF-equivalent in terms of FoV and DoF.
It's pretty effective: with my feet steady, it's almost like a tripod; walking, it's as if a very inexperieced guy was operating a badly-balanced steadycam (bad, but sometimes acceptable).
Intelligent active steadyshot adds an extra 1.31x crop, bringing it to a total of 3.5x, which means the lens becomes a 31-92mm f/6.3-9.9 FF-equivalent in terms of FoV and DoF.
It's slightly more effective than active steadyshot.
All those modes are available at 24fps, 30fps and 60fps. When you move to 120fps, only off and standard are available.
I'm going to leave "standard" as my default option. It's what I'll use most of the time.
I've also been following this thread with interest.
Picked up a RX100M4 a couple weeks ago. Had a last minute trip to one of the less camera-friendly lands, & needed a stealth cam for some B-Roll.
Not sure I want to bother with S-Log on this camera & have been using "Spreeni's modified version" of "Kholi's Cine2/Pro PicPro" for the A7s. So far it looks good, but needs more testing.
http://www.dvxuser.com/V6/showthread.php?334121-a7s-Picture-Profile-Compilation-2015
The user manual is the typical Sony gibberish so I downloaded "Photographer’s Guide to the Sony DSC-RX100 IV" to my Kindle apps. The book is heavy on Photo 101 but still useful for anyone trying to adopt this camera.
http://whiteknightpress.com/photographers-guide-to-the-sony-dsc-rx100-iv/
My first piece with the RX100 IV shooting 4K.
Thoughts:
- It's SHARP.
- I can't edit 4K on my laptop. I can edit 4K on my two-years-old desktop, but it's slow when it doesn't have any effects, and painfully slow when it has all the color grading applied. I would need a better GPU if I was to work with 4K files more often.
- AF doesn't work as well in 4K as it does in 1080p. Or at least that's the impression I got when looking at the footage at home: it loses focus much more often, and doesn't seem to be doing the face-detection thing at all.
- AWB works pretty well, but it will bite you in the ass from time to time. I have a couple of weird shots where the color jumps for just one frame; it could be a bug in the color grading suite (MB Colorista and Looks; not latest version because if I upgrade I may lose compatibility for some stuff I'm still working on), but more likely it's a one-frame AWB issue.
https://www.youtube.com/watch?v=3QYG-FwKrrc
I'm renting one for the slow motion feature this month to test it out and may consider buying it. Being a small pocket camera I could take it anywhere and hide it anywhere while still shooting footage that easily cuts with the F3 and FS7 from what I hear. It's either that or maybe an A7RII if I get lucky and get a good used one or a huge discount haha (would become my main stills camera as well but I just can't justify 3 grand on a camera that will be worth 2 grand in a year or so while my Nikon D750 does fine for studio stills).
4k is nice as well and the size will fit on my gimbal so who knows it might even replace the a6000 depending on how useable the low light is for wedding video work on the nebula.
The R100M4's 120fps works fine, but playback in-camera is not slomo, so strobing (etc) cannot be readily observed.
The higher framerates do playback in slomo however they devour batteries. Haven't used the HFR mode often, but estimate 10-15 minutes of standby/recording per battery.
Hi Samuel, have you had issues with the camera overheating when recording in 4K? I know Sony specifically says you are limited to about 5 minutes of shooting times when recording in 4K, but I had quite a different experience when I tried the camera out in store. I was getting about 2-3 minutes worth of footage before the camera refused to record because of the heat. I was surprised at that since I was testing the camera out indoors. I'm wondering if this issue has been fixed via an update or if you have any tricks on working around it. Thanks!
I had no issues at all... but I think my longest take was around 40 seconds. I don't do takes of more than 1 minute very often.
This is not "first impressions" anymore because I've had the camera for over a year. My summary so far: the more I use it, the more I like it. The only thing I would ask for is somewhat better AF, which is precisely what the RX100 V brings to the table. Other than that, the things I want are still not on the a7 series so of course they're not on the RX100 either (things like better DR and 4k 60fps).
The news is... I recently shot this short piece, and I was surprised that I actually managed to get shallow-enough DoF. Not crazy shallow (which usually I don't like anyway) but shallow enough to separate different planes on the image. Which I found really surprising because in terms of DoF the lens is FF-equivalent to 24mm f/5 and 30-70mm f/7.5. I thought I'd be stuck with deep focus for all shots, and I was happy working under that limitation, and then this happened:
Full video here:
https://www.youtube.com/watch?v=-fbl_bxz6bE
(still no issues recording 4k with the kind of a-few-seconds-to-two-minutes takes I shoot; I haven't ever seen even a warning, but I think I still haven't taken a 4k clip of more than three minutes)
It's been 20 months already, and really: apart from the fact that I miss shooting with my vintage Leica glass, I really find no reasons to upgrade from the RX100 IV: the image is just lovely.
In this last short (I uploaded it yesterday) I could fully control the lighting most of the time, instead of going with my usual "available light plus a couple of quick fixes", and image quality has improved much more than it would if I had shot with a camera 10 times the price of the RX100.
https://www.youtube.com/watch?v=GdjorEd0hKU
