[FS: Support] RTMotion Mk 2.5 kit
andyjar
Selling my RTMotion Mk 2.5 kit. Works perfectly, just haven't been using it enough to justify keeping it around!
Kit includes:
RTMotion Mk. 2 Transmitter
RTMotion Mk. 3 Motor
RTMotion Mk. 3 Receiver
2x .8-mod gears
1x .8-mod gear, double width (good for zooms)
1x .5-mod gear
1x .6-mod gear
2x P-tap power cables
1x 4-pin XLR power cable
1x motor cable
1x RED ONE AUX RS cable
1x RED EPIC RS cable
Receiver rod clamp (15mm/19mm)
1x 15mm rod clamp
1x 19mm rod clamp
2x additional marking discs (Made with my laser cutter, if you want I can make more)
Lanyard
Spare Antenna
Pelican case
What's so awesome about the RTMotion?
-Smallest receiver in the industry. Seriously, it's crazy--fully rigged this thing has less of a profile then a regular follow focus.
-Native support for 3 motors
-Powerful system, allows multiple receivers to be hooked together for more motors or 3D Sync
-Long range, basically unlimited. A thousand feet or more.
-Fully tunable, can adjust motor smoothing and response on the fly
-Can hook the receiver up via USB and interface with it for motion control
-Really well built, the system feels ultra solid
-The controller can have 30 lighted focus marks. You press the button and an LED lights up any time you hit that exact point. Good for "inbetween" marks.
Asking $3000.
