Barry_Green
Moderator
Hey, just ran into an article talking about how the Red doesn't like shooting under fluorescents:
http://provideocoalition.com/index.php/aadams/story/red_vs_ace_hardware/
They included a sample video, which looks very much like the results I got on the Red when shooting with a magnetic-ballast HMI (although you can greatly exaggerate the effect by using a shorter shutter speed).
Anyway, it got me to thinking as to why the EX1 probably defaults to "shutter off" when in 24P mode. 1/48 = banding under fluos/hmi's, whereas 1/24 = no banding.
The reason has to do with the cycle of 60Hz lights. In order to avoid banding, you'd want your shutter speed to be a multiple of 1/120. So, 1/120 = no banding; 2/120 (i.e., 1/60) = no banding, 3/120 (i.e., 1/40) = no banding, 4/120 (i.e., 1/30) = no banding, and 5/120 (i.e., 1/24 or "shutter off") = no banding. This is going to affect any rolling-shutter camera.
So that's probably why Sony chose "shutter off" as the default. If you're shooting under fluos or magnetic HMI's, you shouldn't use 1/48 -- try 1/60 or 1/40 instead.
High-frequency electronic ballasts should overcome this issue, but you may be in a mixed-lighting situations, so better to be safe than sorry (banded). I also tried this test on the Red using the Cool Lights electronic-ballast HMI and didn't notice banding at shutter speeds up to about 1/500, so that's pretty much "safe". But magnetic ballast HMI's or low-frequency fluorescents are going to give you fits if you don't use the right shutter speed.
