Rokinon Lenses on AF100 would need Support or not
Pete26
I am very excited to get the Rokinon kit in couple of days. Please share your view whether or not a lens support is needed for using Rokinons with the AF100. If yes, what are some good and cheap lens support mounts. I am getting the lenses with Canon EF mount, not sure how that looks and serves the purpose of lens support or not.
The Rokinons are not heavy or long enough to warrant a lens support, you'll just be adding extra bulk. Unless of course you have a really bad lens adapter with a lot of play.
Thank you everyone for your comments. For now I would not worry to put a lens support. But will assess the need after I start using the kit.
Hell I don't even use lens support on my Tamron 70-200. The AF100 is more than strong enough for it. Anything bigger I definitely would.
Panasonic quote 1000gms as the max unsupported lens weight. But I would think the other dynamic to consider might be length. Managing the stability of a physically long lens may require extra support- it becomes a long lever on the mount.
Cheers!
Rod
