rokinon 14mm f2.8
it should cover fine on the 7D with minimal vignetting since it was designed for full frame.
The distortion is a bit odd with this lens: almost a moustache type. search for it on photography-on-the.net forums, they have a really good thread over there.
That being said, this is an incredible lens. Very sharp, comparable with the Canon 14mm for alot cheaper.
I would also look at the 11-16 f/2.8 from Tokina if you are looking for a UWA for your 7D.
I have the bower version of this lens. I think the same company makes these. I think it's a great lens. Its my go to lens for street photography + landscapes. Lots of reviews online.
They are all the same lens.
A koren company called Samyang is the company that designs and produces the lens (they also make a 85 1.4 that is good, and are coming out with a 35 1.4 shortly) and other companies market them under their name.
thanks. could not find the tgread though.
Thank you so much, I'm probably going to get it since I'm an amateur and really only interested in use for filming.
