SOLD RODE VideoMic Pro
Status
Not open for further replies.
Erik Naso
RODE VideoMoic Pro-4.jpgRODE VideoMoic Pro-2.jpgRODE VideoMoic Pro-3.jpgRODE VideoMoic Pro.jpg
Lightly used for one project that has come to an end. $170 Paypal friends and family payment. FREE shipping CONUS.
The RODE VideoMic Pro is a VERY GOOD Shotgun mic for any camera with a 3.5mm plug. I used this with a GH4. Out performs on board microphones built into the camera and better than most Condenser mics in its class.
The VideoMic Pro from Rode packs the audio quality and features of the popular VideoMic into an ultra compact and lightweight design that's ideal for use with HDSLR cameras, camcorders, and audio recorders. The microphone has a broadcast-quality condenser capsule with a supercardioid pickup pattern to capture audio from the front, while minimizing pickup from the sides and rear. An integrated shockmount and foam windscreen minimize handling and wind noise to keep your recordings crystal clear.
On the rear of the mic, you'll find a 3-way level control that offers -10dB, 0dB, and +20dB modes. There is also a 2-step high pass filter with 0 and 80Hz settings, letting you minimize the impact of low frequency hum, camera motor noise, and similar distractions. The mic has a standard camera shoe and a 3/8" threaded mount for easy attachment to cameras and boom poles. The 3.5mm plug is compatible with a wide variety of different cameras and audio devices. The VideoMic Pro operates for up to 70 hours on a single 9V battery, allowing you to work in the field without constant replacements.
Compact and LightweightUltra compact and lightweight design with a rugged construction that's ideal for use with HDSLR cameras, camcorders, and audio recordersCondenser CapsuleThe broadcast-quality condenser capsule has a supercardioid pickup pattern to capture audio from the front, while minimizing pickup from the sides and rearIntegrated Shockmount and WindscreenThe integrated shockmount and foam windscreen minimize handling and wind noise to keep your recordings crystal clear3-Way Level ControlThe 3-way level control offers -10dB, 0dB, and +20dB modes, letting you set the perfect level regardless of what device the mic is connected toHigh Pass FilterThe power/HPF switch lets you turn the mic off, set it for a flat frequency response, or engage the 80Hz high pass filter. The filter minimizes the impact of low frequency hum, camera motor noise, and similar distractionsVersatile MountingThe integrated camera shoe and 3/8" threaded mount offer easy attachment to cameras and boom polesStandard PlugThe 3.5mm plug is compatible with a wide variety of different cameras and audio devicesLong Battery LifeThe VideoMic Pro operates for up to 70 hours on a single 9V battery, allowing you to work in the field without constant replacements
Status
