I've used it on a few short films, but I'm at the point where I'd rather hire a sound guy than do it all myself. The Micover slipcover is amazing at getting rid of wind noise. A test showing the advantage over the deadcat is here: http://www.dslrfilmnoob.com/2012/03/03/rode-deadcat-v-s-micover-windscreen-video-review/
RODE VIDEOMIC
The RØDE VideoMic is a professional grade shotgun microphone. Based on the latest 'Film industry' technology, the VideoMic is designed specifically for use with high quality digital video cameras.
Enjoy studio recording quality with pro features like integrated shockmounting, a two-step high-pass filter (flat or 80Hz), and a three-stap pad (0, -10, -20dB).
The microphone exhibits low noise and an unusually wide bandwidth for its size. It is ultra lightweight, yet rugged due to its ABS construction. The VideoMic is powered by a standard 9V battery and offers a low battery LED status indicator.
Integrated shock-mounting and the switchable high-pass filter reduce unwanted low frequency rumble, and a windshield is also included.
The VideoMic attaches to any camcorder that has the standard camera-shoe fitting and utilizes a stereo mini jack for audio output.
VideoMic Specs
MICOVER SLIPOVER WINDSCREEN FOR RODE VIDEOMIC VM
The Micover™ Slipover Series is made of high-quality synthetic fur. Your microphone, with its original black foam cover, provides between 5dB and 10dB of noise reduction. The Micover™ Slipovers reduce unwanted noise by an additional 10dB without diminishing the quality of your recording.
I'm based in Los Angeles, CA (West Hollywood specifically). You can pick it up or I can ship it. Comes with a FREE 9V battery
$109
RODE VIDEOMIC
VideoMic Specs
- Power: 9V battery powered (battery sold separately)
- Acoustic Principle: Line gradient
- Directional Pattern: Super Cardioid
- Frequency range: 40Hz-20kHz, selectable HPF @ 80Hz/12dB/octave
- Output impedance: 200 Ohms
- Signal noise ratio: 74 dB SPL (A - weighted per IEC651)
- Equivalent noise: 20 dB SPL (A - weighted per IEC651)
- Maximum SPL: 134dB SPL (@ 1kHz, 1% THD into 1KOhm load)
- Sensitivity: -38 dB re 1 Volt/Pascal (15 mV @ 94 dB SPL) +/- 2 dB @ 1kHz
- Weight: 176gm
- Dimensions: 65mmH x 250mmW x 102mmD
$109
