[FS: Audio] RODE NTG-3B B&H Signature Series Boom Condenser Microphone
chlywly
Selling my trusted and babied NTG3B. These are sold out everywhere currently. Sold out almost everywhere)
MINT condition. Has been babied.
Looking for $600USD Shipped to USA/Canada
Capture broadcast-quality sound indoors or outside for your next indie film, TV shoot, or documentary project with the black Rode NTG3B moisture-resistant shotgun microphone. Professional-level features such as low-noise circuitry, upgraded immunity to radio-frequency interference, and minimal handling noise reduce the need to repair and restore audio in postproduction.
The NTG3B's high sensitivity allows it to produce strong output levels without having to apply extreme gain at your mic preamp. Sonically, the NTG3B delivers consistently clear sound due in part to its gentle rise in high frequencies and its rumble-reducing attenuation of low bass frequencies. Its switch- and dial-free design lets you set up quickly and focus on the sound instead of fiddling with various mic settings. The solid brass housing is both durable and lightweight, and its anti-glare finish prevents reflections in the shot.
Form Factor Stand/Boom Mount
Sound Field Mono
Operating Principle Line Gradient
Capsule Condenser
Diaphragm 0.5" / 12.70 mm
Polar Pattern Supercardioid
Orientation End Address
Circuitry Solid-State
Pad None
High-Pass Filter None
Tone Adjustment None
Indicators None
On-Board Controls None
Windscreen Foam (Included)
Performance
Frequency Range 40 Hz to 20 kHz
Maximum SPL 130 dB SPL (1 kHz, 1% THD, 1-Kilohm Load)
Off-Axis Rejection 8 dB at 60°
18 dB at 120°
17 dB at 180°
Impedance 25 Ohms
Sensitivity -30 dBV/Pa at 1 kHz
Output Level 8.2 mV (Max)
Dynamic Range 117 dB
Signal-to-Noise Ratio 81 dB A-Weighted
Equivalent Noise Level 13 dB A-Weighted
Connectivity
Output Connectors (Analog) 1 x XLR 3-Pin
Power
Operating Voltage 48 V ± 4 V
Operating Current Consumption 5 mA
Physical
Color Black
Mounting 3/8"-16 Female, 5/8"-27 Female, Mic Clip (with Included Hardware)
Construction Material Brass
Dimensions ø: 0.75 x L: 10.04" / ø: 19 x L: 255 mm
Weight 5.75 oz / 163 g (Microphone)
Packaging Info
Package Weight 2.06 lb
Box Dimensions (LxWxH) 13.1 x 6.7 x 3.15"
