I wanna get it as my first run-and-go mic. I will shoot mostly outside (and it should do better inside as 416 through the wider pick up pattern). Which shockmount would you get for it? And what wind protection is recommended?
Cheers,
Yannick
would be this one:
http://www.bhphotovideo.com/c/product/554999-REG/Rycote_041107_INV_7_InVision_Indoor_Microphone.html
This works as good as rubbers?
And which windscreen do you say?
would be this one:
Wow, certainly more expensive than 18cm Small Hole Softie - $110,
What will I gain? Better sound quality? Les hassle?
The Rode NTG-3 is 255mm and has a black foam windscreen which should make it even longer.
Rycote S-Series 330 Windshield and Suspension Kit - Fits Microphones Measuring 10 - 11" (260 - 280mm) Long
http://www.bhphotovideo.com/c/product/497432-REG/Rycote_010302_S_Series_330_Windshield_Kit.html
There is also a 200mm - 255mm, but I assume it's too small.
But I don't read anyhting of Rycote INV-7 in the specs.So I guess I have to order both??
Can I use it also with the MKH8050 later or do I have to buy such an expensive windscreen twice?
Would the premium line windshields of Rycote add much to quality (it's about 240$ more)?
Do I need another set of lyres? With the InVision Suspension I would need the INV-7. I wonder what lyres come with the s-series as I haven't seen it stated anywhere.
Okay. Do you use the angled or non angled xlr cable for it?
That price would be the Softie only - a Softie with shockmount/pistol grip and Softie tail is slightly more than the equivalent S-series kit.Wow, certainly more expensive than 18cm Small Hole Softie - $110,
BothWhat will I gain? Better sound quality? Les hassle?
You do *not* use the foam windshield inside a basket windshield - it would make the wind protection *worse*.The Rode NTG-3 is 255mm and has a black foam windscreen which should make it even longer.
You can use the same, just buy smaller pods.Can I use it also with the MKH8050 later or do I have to buy such an expensive windscreen twice?
Thank you guys for your input
No I meant the difference among rycote windshield kit 3 (595$) versus the rycote s-series 300 (349$). This probably only can be answered by somebody who worked with both. I prefer to buy once and be happy, I don't have the money to buy twice and I don't wanna make compromises with sound. But if it makes no sense to go expensive then it shall be so.
Is there any sense in using it at all anymore if I get a zeppelin?
