SOLD Rode NTG-1 Condenser Shotgun Microphone + Universal Shock Mount + 10 Year Warranty
Status
Not open for further replies.
HD-tography
Like New, Zero Use! Full 10 Year Transferable Warranty!!!
Perfect For Use With Zoom H4n or TASCAM DR-100!
High Off-Axis Attenuation
Includes Foam Windscreen and Microphone Stand Mount
BONUS: Pearstone DUSM-1 Universal Shock Mount for Camera Shoes and Boompoles! ($50 Value)
Price: $225 + 3% PayPal Fee (Or Send Money As Gift) + Actual Shipping to ConUS, Canada, and some places in Europe (PM me for shipping quote)
Shipped From North American Location (Canada) The Day Following Cleared Payment
I only accept PayPal
Also Check My Other Items For Sale, Massive Liquidation Of New & Like New Professional Camera & Cinema Gear! Everything Must Go!
To See Even More Photos Of This Massive Sale Visit:
http://photobucket.com/TheGreatLiquidation
The Rode NTG-1 Condenser Shotgun Microphone is designed for professional audio capturing in the field or indoors. With a history of manufacturing quality studio microphones, Rode has implemented low noise output electronics and wide bandwidth, both of which attribute to the NTG-1's broadcast sound quality.
The supercardioid polar pattern and line plus gradient acoustic principle effectively minimize audio and noise at the off-axis (sides) of the microphone, while the front of the capsule accurately reproduces incoming audio signal. The result is greater intelligibility and signal-to-noise ratio while using the NTG-1 in noisy environments.
The NTG-1 is powered with an external +48 Volt phantom power source; the output is a standard 3-pin XLR male connector.
The microphone features a rugged, all metal, light weight enclosure that is ideal for camera mounting yet durable enough to withstand the rigors of heavy road use. The Rode NTG-1 is packaged with a microphone stand mount and windscreen.
Super-Cardioid Polar Pattern
The super-cardioid polar pattern and line gradient acoustic principle allow for a narrow pick up pattern at the front of the capsule while minimizing noise at the off-axis sections.
Lightweight Durable Construction
The NTG-1 features a lightweight metal housing that is ideal for camera mounting.
Low Handling Noise
Low noise output electronics provides high signal-to-noise ratio. The NTG-1 is designed to also reduce noise caused by handling, rigid mounting hardware, loose cabling etc.
Transducer Condenser
Polar Pattern Supercardioid
Frequency Response 20Hz to 20kHz
Dynamic Range (Typical) 121dB (per IEC651, IEC268-15)
Signal-to-Noise Ratio 76dB (1kHz rel, 1Pa; per IEC651, IEC268-15)
Maximum Input Sound Level 139dB SPL (@ 1% THD into 1k ohm)
Power Requirements +48V phantom, 44V to 52V
Output Impedance 50 ohms
Output Connectors 3-pin XLR balanced
Pad No
Low Frequency Roll-Off Yes
Dimensions (LxDiameter) 8.54 x .87" (217 x 022mm)
Weight 3.7 oz (105g)
Four-Point Silicone Suspension
Fits Mics Measuring 19-25mm In Diameter
Built-in Shoe Mount
3/8"-16 Thread Base for Boompoles
The Pearstone DUSM-1 Universal Shockmount features a four-point suspension to accommodate shotgun and other cylindrical microphones measuring 0.74-0.98" (19-25mm) in diameter. The shockmount is easily angled with its rubberized adjustment knob. There is a built-in shoe for camera mounting and a 3/8"-16 thread connection at the base mounts the shockmount to boompoles and universal hand-grips.
Status
