Right angle XLR to mini jack (3.5mm)
novoluc
Hello out there,
I thought that would be easy to find, but no luck... I need a short cable with a right angle XLR female to a mini jack. I find all the right angle XLR to XLR or straight XLR to right angle mini jack but can't find what I'm looking for.
If you know a place where I can order that I would really appreciate you telling me (I'm trying really hard to not having to buy the parts and soldering iron and doing it myself...).
L.
Ebay is usually good for that kind of stuff but if you can't find it
learning to solder really isn't that hard. Buy a cable with 3.5mm ends snip it (so you only have to solder one end)
and get yourself a right angle xlr. Xlr's are definitely one of the easiest things to solder out there.
Once you get the basics you'll be glad you learned. I have a stockpile of connectors and bulk cable and it's really nice
to be able to make anything you need or want. Save a crap ton of money as well.
Thank you all for the suggestions. I'm ordering a custom cable, which I need ASAP, and a soldering iron!
and of course a readymade one would need to be wired specifically your way - as in balanced to unbalanced - 2 circuit or 3 circuit 3.5mm, depending on what you need.
