RGB Parade Help - FS700 Blues
Chad Nikolaus
Hey all, i'm learning as much as i can about my FS700 really trying to understand things. Love it so far.
However, one thing i've noticed with almost all of my footage is that the RGB Parade in CS6 shows Blues very different than Red or Green. I don't quite understand why, or how to fix it if it's something that shouldn't be happening.
http://postimage.org/image/h7l2z6kot/
This image is Cine 3 default settings. White balanced to a white cloth (dont have a grey card right now). I get about the same result with Cine 1 and 4.
In post, i will typically use RGB curves to change the blue in RGB Parade to match closer to the Green and Red. To my eye, it does seem to create a more natural and pleasing color.
As you can probably tell, i'm not trained and just kind of trying to learn the ropes.
Should the blue in RGB Parade differ so much from the Red and Green? What might i try in camera to tweak that so i wouldn't need to in post every single time?
Any help would be nice, willing to try some tests and post results.
AWB works by adjusting the blue channel in camera - that's what you see there.
There are differences in dialing in a color temperature vs doing an auto WB on a grey/white card though.
The dialing in adjusts just the blue channel, whereby the WB does his voodoo in a 3D matrix affecting green/magenta and blue/yellow.
As long as the picture looks fine, there is nothing to worry about, it's just the way it works.
Frank
