I suppose that anyone can restore original firmware of the camera. However, according to service manual, the error codes cannot be initialised (erased). What does it mean? Each error produced in camera is stored within camera's memory (camera's FLASH ROM) and up to 16 errors can be memorised. So, if somebody is frequently changing bitrate settings, it will likely produce several writing errors which will be recorded inside the camera. It probably won't mean anything when taking the camera to repair service, but it is good to know that our "attempts" are recorded. I suppose that errors are not initialised by changing the firmware.
By the way, according to service manual, there are two errors related to "Motion Image Recording". Namely, error "3F000001" which means "File time error in recording motion image" and "3F000002" which is "File data cue send error in recording motion image". Has anybody tested which error occurs when bit rate is too high?
