Anyone know how to reset the TC on the AF102. Coming from a DVX102 when you insert a new tape, The TC will starts from zero. However I can only successfully reset the clip timing but not the "TC 00:00:00".
In the panel where the LCD sits when closed you'll see the WFM (waveform monitor button), under it is a button with RESET/TC SET, press it and you will see all the numbers in the TC PRESET screen reset to 00h00m00s00f. So once you've done that push in the little menu selection joystick. An overlay pops up that says TC Preset? Select YES, push in the little menu joystick again and your done.
