REQUEST: Speedbooster on FF DSLR camera
macgregor
Hello everyone, lets see if someone could please help me here.
I'm curious to see what happens when you use a focal reducer adapter in a full frame mirrorless such as the a7rII or the a7s.
Yes I know focal reducers are meant for APSC cameras, but that´s exactly what I want to see. Does the adapter itself create vignetting? If someone could grab a couple pics with a few different lenses that'd be great.
I'm asking all this because my intention is to use a PC-E / TS-E lens, which has a much bigger image circle than the average FF lens, with a speedbooster onto a Full frame sense on the a7RII. So before buying it'd be great to know if this works. Makes sense?
How much of the sensor was covered would probably depend on the particular booster you were using. I would think you would get a heavy porthole-type effect, where the edge of the projected image is seen. And even though you might end up "seeing" a larger image than you would with a plain adapter, or with that lens on its native FF DSLR, who knows if that extra image area is even worth having- it may be distorted, blurry, or a mess of CA or other image defects.
I think what you would need to do ideally is use one of the medium format-to-FE boosters that were announced a couple months ago, and find a way to adapt your desired lens to those (if even possible, I think most MF lens mount systems have a much longer flange distance than any 35mm mount system). Since these boosters are designed for a larger-than-35mm image circle it should in theory give you what you're looking for.
You are correct aldolega, but those tilt-shift lenses also cover essentially medium format sensor sizes, so what I'd like to see is if the speedbooster does or does not portholes as you mention. Worth the try!
I remember putting a Metabones Ultra on a Sony A7 series and whacking different lenses. It seemed clear to me that there was a pothole effect from the Speedbooster itself.
