ullanta said:Two per channel? Really?
Summed?
ozduc said:Maybe they are set up in such a way that when you use the external inputs on ch 1 & 2, then it is the second stereo pair that records to channels 3 & 4
ullanta said:...that's pretty much the goal of this project....
ullanta said:So you're feeding it a line level signal? Can you recall how much gain you're adding to the Oktava (from the tube pre and the dvx gains)?
ullanta said:Any chance you have a dynamic or battery-powered mic that outputs a mic-level signal to test directly?
