Rodney V. Smith
DVXFest Promo Guru
I got a varizoom monitor pretty cheap about a week ago and quickly discovered that the battery refused to hold a charge. My other battery that had come with my 5.6 Marshall was essentially a brick and was hard to place anywhere... plus I went and lost the power adapter... so I could no longer charge it.
All I wanted was something that weighed less than 1lb, and could poentially fit onto the back of the monitor... a nice light weight solution.
THen I came across this little puppy...
here the link to the product site: http://www.xantrex.com/web/id/233/p/1/pt/5/product.asp
It says its supposed to give 2 hours of use on a laptop, so I've decided to test it out. I;ve charged it up (3 hours initial charge),applied some velco to the back of it, and now it's sitting on the back of my monitor...
We'll see how long it powers the unit for.
One of the other things that I considered this to be useful for was immediate and lightweight backup power for camera, onboard lights... anything that needs a quick power boost. After this initial test with the monitor O'll have to test it to see if I can split the power to run 2 things at once....
I managed to pick this one up for $50 and I know Balck and Decker has a similar unit for $40-$50.
