Replacement battery for $28.24
Kimchoc
I researched a replacement battery about 10 days ago and came up with this.
2640mah battery that will work with the power meter display on the battery. Apparently some aftermarket batterys from China don't work with the display meter.
I just dropped mine on the camera. Works fine. Got it in the stock charger now and charging up. Apparently some from China dont use the stock charger either.
I got it from a google search. CellularFactory.com . $28.24. "Replacement for VW-VBG260"
I thought the price was pretty good. I looked at the Panny bat price and said NFW.
Price low enough here to get a few.
Hope this helps..
GLB
Thanks for posting this! I recently plunked down for 3 of the larger 5400mAh batts that others have endorsed here:
http://www.dvxuser.com/V6/showthread.php?219296-Panasonic-HMC150-VW-VBG6-battery-Decoded-Chipped-40
I previously got one of the extended Panny batts to go with my HMC40, and it works GREAT! It lasted for a whole day long wedding shoot (no power-offs, continuously recording for a 1 hour service, and ~2 hours worth of the reception ON ONE CHARGE!). That said, $160 for a battery is a bit silly, provided there are $30-40 alternatives that perform nearly as well.
