What's the best template to use for rendering clips I intend to post? It seems like everybody uses .mov files. What are the best video options do get a managable file size and decent quality?
Yes , i'm wondering the same thing. I normally use the media encoder that comes with Premeire pro but exporting to quicktime usualy results in a loss of audio quality and i can't seem to make it decent sounding. Windows media is pretty good though.
So what's the secret to getting nice looking .mov's with good sound quality and respectable file size.
Like the ones on the quicktime site are high quality and audio sounds ok, but their file sizes are so low... They must use better encoders right?
Quicktime definately uses Software based compression.
Unless you have a specific board that is tailored to work with a specific Codec.
of course if you want to get technical.. you could say that even software based compression is hardware based.. since incidently the software runs on the hardware
and just for clarification, "rendering" isn't a correct term in this instance, rendering takes place upon decompression and display of the frame.
Compression is the correct term here.
and to answer the actual question here
.mov files have nothing to do with file size, that is just a designation for a Quicktime File.
QT supports over 20 different Codecs... it is a matter of choosing the right one that will give you the best quality vs. file size.
In some respects I would say Windows Media is better at this point in time.. in terms of both quality and file size.. but that will be debatable when the new MPEG4 standard H.264 gets rolled into QT Pro.
as of now.. on the mac.. under quicktime my personal choice for codecs is:
[quote author=RJ link=board=Clips;num=1109366882;start=0#2 date=02/25/05 at 17:36:30]reflex what do you edit with? Premier Pro?[/quote]
yes. I've been just using the encoders taht come with the program. windows media DOES seem to do a much better job.. but somepeople can't view Windows so I'd rather know what to use for QT files...
I use VEGAS and Render as an MPEG 2. Full size; and then SQUEEZE in Sorenson. I agree, it does an incredible job of compressing. I recently turned a 220 MB 720 X 480 into a 29 MB 480 X 266 (Crop the balck bars off with Sorenson).
Here are some Quicktime Conversion settings that work for me:
Settings
I use Sorenson Video 3 because it has the widest compatiblity. I actually prefer On2 VP3 (higher quality, smaller file size) but a lot of people don't have that codec on their player.
I use anywhere between medium or high quality setting depending on the
quality/file-size I want.
Uncheck "limit data rate". Thats more for streaming video and will over-ride your quality setting.
If you want to reduce your file size you can go as low as 15fps.
Filters
Adjustments>HSL Balance> Raise the "Lightness" anywhere from 110-115. This will compensate for the "darker look" compressed movies get.
Size
I use custom sizes. 640x480 for large file size or 320x240 for small file size.
Sound Settings
For compressor I use IMA 4:1. There are a couple that will give you a smaller file size (like Qdesign Music 2) but your quality will really suffer.
A tip I learned from a tutorial somewhere (I wish I could find it again) is to lower your Audio Rate to 32khz and check mono instead of stereo to shave off a bit of your file size without affecting the quality too much.
