GH2 Remembering Sandy
rokkor
I decided to take a walk to survey the local damage caused by Hurricane. This short was cut together from those clips recorded just in a 2 block radius, just scratching the surface. Also decided to experiment on the grade...
Excellent video. Held my attention throughout. Perfect blend of music,broadcast dialog.
Goes to show you how important the music is to set the mood of the flick.
You held true to your signature...."it's not what or whom you use, it's how you use them"
Thanks for sharing,
Jeff
Thanks Jeff, much appreciated. I like the way it turned out, given the fact it was unplanned. A good vision, a carrying out that vision is what get you good results. The camera debate will always be an issue, technology is on the film makers side now. Thanks again for watching.
