Squirrel
That chart is totally wrong for 4/3. It's using numbers that are somewhat close to S16 film, but nowhere near what the 4/3 sensor is.
Sorry, in this case the chart is wrong: the real dimension of the AF100 sensor in 16/9 is actually bigger: 18,8x10,6mm (it has the same diagonal than the 4/3 picture mode: 17,3x13mm).Yes, the AF100 sensor is identical in size to the GH2 and GH1 sensors.
The AF100's sensor specification has been published in the user's manual as 17.8mm x 10mm.Sorry, in this case the chart is wrong: the real dimension of the AF100 sensor in 16/9 is actually bigger: 18,8x10,6mm (it has the same diagonal than the 4/3 picture mode: 17,3x13mm).
Well, in this case the GH2 sensor, in 16/9 mode, is bigger than the AF100 one, according http://forums.dpreview.com/forums/read.asp?forum=1041&message=36396593The AF100's sensor specification has been published in the user's manual as 17.8mm x 10mm.
Yes, I'm well aware of that claim. However, I don't know whether it holds true in video or not. The Gh2 does video and stills, the AF100 is video only. It's possible that the 17.8 x 10 is a mathematically-appropriate extraction which makes for better video (similar to Red's 3840x2160 mode, which is designed for 16x9 HD video). Or maybe the GH2's sensor is the same size. I don't know that for sure. All I do know is that the specs have been published at 17.8 x 10.Well, in this case the GH2 sensor, in 16/9 mode, is bigger than the AF100 one, according http://forums.dpreview.com/forums/read.asp?forum=1041&message=36396593
B&H has a nice chart for stills cameras on their site to show the relative focal length needed on various stills cameras to achieve certain fields of view. But it's not very adaptable to the AF100 or cinema cameras.
Here I've put together a chart that shows the sensor sizes of common video and film formats, their Cinema Crop Factor as related to Academy Aperture 35mm Cinema Film frame size, and normalized for 16:9 image shape. It's not all that easy to put together a field of view chart when comparing different aspect ratios, so I normalized all the sensors for their widest 16:9-shaped field of view.
Without further adieu...
Im sure this has been posted, but i dont wanna search 52 pages. Is the af100 crop only 1.19 and not 2.0 like the gh1/gh2??? thats confusing
It's a 1.19 Cinema Crop Factor. Comparing the AF100 to its logical alternative, 35mm cinema film.
In reference to "2.0", that's comparing it against STILL film, not movie film. And in that comparison yes the AF100 would be a 2.0.
Awesome, thank you.correct, s35/super35/digital35/35mm motion film are all analogous with the same size and those lenses on the m43 will be about 1.19 crop
