Bruce Watson
I'm going to need a field reflector in the not to distant future. By field reflector I mean something I can easily fit in a car for transport, so my usual white foam core sheets are out. I've tried it, they don't survive a long trip well -- just too big (or, the car is just too small, take your pick). Of the collapsible variety, I find the round spring-metal "twist to collapse" reflectors to be a pain. Too flimsy, the reflection material gets all wrinkled and creased (the frame doesn't pull them taut enough), the arms that hold them are too weak to hold them in some positions, and the slightest breeze drives them crazy.
So, I'm looking for something better. I've about settled on a small Wescott Scrim Jim frame, grip arm, etc. for use on a c-stand. I can pull it apart and roll the material up for compact transport. It's a fairly rigid frame and holds the material fairly taut. Using a grip arm on a c-stand should make for easier and more reliable positioning. I have no idea what it'll do in any wind, but it can't be any worse :happy: And if I need bigger, I can just buy extensions and bigger reflector materials while reusing the rest. Kinda sorta.
Before I commit, are there other systems of the Scrim Jim level I should evaluate? I've looked at the Mathews Road Rags, but find them to be a bit too small (24 x 36 inches) for what I want. I like that 1 meter square size (42 x 42 inches) from the Scrim Jim. What else is out there I should be looking at?
The reason I'm asking is I want to buy this thing just once and forget about it if I can. Sorta like buying a good tripod. I hope. :happy:
