[FS: Support] Redrockmicro Mattebox, Follow-Focus, tripod camera rig
moldcad
Hardly ever used, in like new condition, bundle consisting of:
1. 1x Redrockmicro microMattebox Deluxe bundle (complete with 2x 4x5.65"/4x4", 360 deg rotating filter holders, set of flags, set of neoprene lens donuts, Swing-away design with 15mm mounting bracket of expanded horizontal & vertical adjustability (see Point c) in the bottom Notes)
2. 1x Redrockmicro microFollowFocus (complete with whips, crank and lens gears)
3. 1x pair of Redrockmicro Professional Grade Iris Rods - 24" 15mm ground stainless steel
4. 1x pair of Redrockmicro Professional Grade Iris Rods - 18" 15mm ground stainless steel
5. 1x Redrockmicro microSupport Baseplate (High Riser)
6. 1x Redrockmicro microSupport Baseplate (Low Riser)
7. 1x Letus universal lens support
8. 1x Manfrotto tripod/camera adapter with long plate
9. 1x Manfrotto tripod/camera adapter with short plate
10. 2x Redrockmicro DSLR Tripod Platform (plate with 15mm brackets)
11. 1x Redrockmicro cheesplate
Notes:
a) Selling as a BUNDLE ONLY
b) Two pairs of 15mm rods, two Tripod Platforms, two microSupport Baseplates (with High & Low Risers) allow to assemble TWO independednt tripod/shoulder/universal rigs
c) Vertical expanded* adjustability of the microMattebox 15mm mounting bracket allows to slide the microMattebox over the 15mm rods and fix it at any distance from the rods' front end, thus effectively overcoming the well-known design limitation whereby the microMattebox could not go backwards past the point where the rods meets and collides with the bottom of its filter stages; the professionally executed modification doesn't spoil aesthetics of the unit at all (as can be seen in the first picture)
Price: Euro 1,000
