djmfoxtrot
[FONT="]The [/FONT][FONT="]microMatteBox Deluxe Bundle[/FONT][FONT="] contains everything in the microMatteBox Standard Bundle, and adds a complete flag kit for additional light and flare management. It comes with everything you need to help control light and flare using a matte box, flags, and filters, and can be upgraded later with additional filter stages or a 19mm swing-away arm for additional compatibility (the microMatteBox Deluxe Bundle comes standard with a 15mm support arm). Rubber donuts provide a flexible method of fitting your 35mm lenses or camera to the matte box to prevent light leaks. The microMatteBox is also compatible with the Arri K2.65028.0 – MB-20 Bellows Adapter. [/FONT][FONT="][/FONT]
·[FONT="] This microMatteBox Bundle requires 15mm rods and baseplate for attaching to your camera. [/FONT][FONT="][/FONT]
·[FONT="] [/FONT][FONT="]H[/FONT][FONT="]eight adjustment +/- 10mm [/FONT][FONT="][/FONT]
[FONT="]The microMatteBox is constructed of aircraft grade aluminum, and features an Impact Resistant ABS shade and lens connector to keep the system as light-weight as possible. [/FONT][FONT="][/FONT]
[FONT="]The microMatteBox Deluxe Bundle includes:[/FONT][FONT="][/FONT]
- [FONT="]microMatteBox wide format shade [/FONT][FONT="][/FONT]
- [FONT="]15mm lightweight (60mm) swing-away arm (rods and baseplate not included) [/FONT][FONT="][/FONT]
- [FONT="]2 universal 360 degree rotating filter stages [/FONT][FONT="][/FONT]
- [FONT="]large 138mm diameter opening for large lens support [/FONT][FONT="][/FONT]
- [FONT="]2 dual-purpose filter trays, supporting 4x4 and 4x5.65” filter sizes [/FONT][FONT="][/FONT]
- [FONT="]ability to add additional stages in 1 stage increments [/FONT][FONT="][/FONT]
- [FONT="]support for 5.65" square filters with optional larger filter trays (available separately) [/FONT][FONT="][/FONT]
- [FONT="]1 wide screen removable matte [/FONT][FONT="][/FONT]
- [FONT="]microMatteBox flag mounting hardware[/FONT][FONT="][/FONT]
- [FONT="]Top eyebrow (French flag)[/FONT][FONT="][/FONT]
- [FONT="]2 adjustable side wings[/FONT][FONT="][/FONT]
- [FONT="]3[/FONT][FONT="] neoprene donuts to fit lenses of varying diameters (diameter of openings [/FONT][FONT="]2", 2.5" & 3"[/FONT][FONT="][/FONT]
$725 Shipping within ConUS included
