redrock micro m2 with steadycam / glidecam
kynantait
has anyone used the dvx or hvx with the redrock adaptor on a steadycam rig?
i assume the glidecam 2000 would not be able to handle the weight of camera + adaptor + lens, so im thinking i will need to spring for the 4000 pro.
any user experiences?
you are right in that assumption, buit i dont even know if the 4000 can take all that weight.
I recently used the HVX with the M2 adapter on a music video shoot. My initial concern going into the day was how to get a right-side-up image. My Steadicam monitor does not auto-flip, neither does the HVX. Because of those factors, I knew I had to mount the camera upside-down on top of my rig.
The solution proved to be a bit easier than I thought. I simply used a low-mode system, but in high mode. The bracket (made by Brant Fagan) basically secures the entire camera system, and then bolts right to the dovetail plate. The camera was secure as can be.
The only problem we encountered was the M2 didn't seem to be made to be hung upside-down. If you look in the pictures, you'll see it is a couple degrees off alignment with the angle of the camera lens. Ultimately this didn't affect the image, so I didn't spend a lot of time troubleshooting, but it would be something I would address if I ever shot with this setup again.
For use on the Glidecam 4000, I agree that the entire setup might be too heavy. Let me know if you've got any questions.
Best,
Afton Grant
damnitt...thats definatley a concern. i dont suppose anyone on the boards who owns a dvx100band a redrock would mind weighing it up? pppppleeease? :)
afton, interesting solution!! i was curious about how to deal with the image flip as well.
Also of note, as always, is how you are goign to pull focus on your 35mm lens.
Afton's pictures show he is using a BFD which, at $4 grand with a motor, is the most economical decent system out there.
Check out what rig Afton is using to fly this: That's a Steadicam Master, it's designed to carry 35mm film and high end broadcast cameras. Granted, there is some extra weight added to the camera for this set up, but not that much.
It would be wishfull thinking to hope that this set up could ever be flown properly on any handheld stabilizer. And that includes vext systems like the Smooth Shooter, which use the sled from a handheld system.
To fly a setup like that, you are looking at upwards for a $7k system - not including the wireless focus gear.
- Mikko
