Filmographer
I am selling my Redrock M2 Micro 35mm Nikon Mount Adapter Kit. The M2 – enables you to achieve cinema-quality video at a revolutionary price.
Kit includes:
- Redrock Micro M2 Cinema Lens Adapter
- 2 18" IRIS Rods
- microSupport baseplate
- 82mm to 55mm Step-Down Ring
- 82mm to 72mm step-down ring
- Redrock Micro Canon EOS mount
- Redrock Micro Nikon mount
- 72mm lens covering/hood
- 55mm lens covering/hood
- Flip module
Futher details:
M2 allows 35mm lenses to be used with your DV or HD camera to create incredible depth-of-field, angle of view, and focus typically found in high-end film productions. The M2 works even with DV or HD cameras that have fixed lenses, such as the Panasonic AG-DVX100, HVX200, and the Sony HVR-Z1U.
The Redrock M2 adapter is the only adapter available in the market that enables you to use both large lens apertures for shallow depth of field, and smaller lens apertures to increase your depth of field. This revolutionary level of flexibility allows you to use a consistent 35mm look for all your footage, not just shallow depth-of-field shots.
The M2 is designed to work with just about every modern DV and HD/V camera available
Features
Achieves cinema-quality depth-of-field
Create stunning images with shallow DOF using 35mm lenses
Use techniques such as racking focus and follow focus to enhance your look
Supports interchangeable lenses to get the exact angle of view and focus you want
Attach a 20mm wide angle lens for your master shots, switch to a 50mm for your standard scenes, then bump up to a 85mm for that shallow depth-of-field close-up.
Uses a wide variety of 35mm lenses – even 35mm SLR camera lenses
Choose the type and brand of lens that works best for you and your budget
Mounts are available for Canon MF, Canon AF, Nikon, PL, and OCT-19, and Pentax.
Interchangeable mounts let you upgrade your lenses as your project or needs change – start with inexpensive Nikon or Canon still lenses, and maybe for the big shoot rent some Cooke or Arri Ultra Primes (just make sure you have the correct M2 mounts – check with us)
Works with the camera you will have tomorrow
DV camera owners desiring the M2 but are looking to upgrade to HD cameras in the future can feel confident their M2 investment.
The M2 is designed to be camera-independent, allowing you to preserve your investment in the M2 as you upgrade your camera. Make sure to check the list of M2 tested cameras to ensure compatibility
Compatible with popular accessories such as Matte Boxes and follow focus units
Uses industry-standard 15mm support rods..
Sample Footage can be found here:
http :// www.redrockmicro.com/micro35.html
Price: $700
Kit includes:
- 2 18" IRIS Rods
- Flip module
Futher details:
Features
Price: $700
