Redrock M2 HD bundle for HVX $1000
Lenilenapi
Carbonite Member
For Sale $1000
Redrock M2 HD Nikon Bundle with all accessories for HVX200.
Includes:
• M2 Cinema Lens Adapter - (current version aprox 1 year old)
• Special M2 HD Achromatic lens
• Nikon SLR lens mount
• 15mm Rod Support System with quick release and 18" rails
• M2 Shim kit (neccessary for the HVX200)
• 82 > 72 step down ring (neccessary for the HVX200)
• Adapter rings for hard or semi-hard* mount option
• Redrock carrying case
Retail value $1460
This system has been meticulously centered and adjusted for optimum focus with an HVX200 . You will save yourself days of work setting up this system and the "semi hard" mount is easy and reliable to set up in production situations.
We have 2 adapters so we're selling off one.
Some Nikon Lenses are also available
Nearly a complete set of fast Nikon lenses 50, 85, 105 and* 135 is also available but not priced yet. Ask us if interested.
* By semi-hard mount - we found that to achieve the optimum distance from the 35mm screen a combination of filter rings mounted on the Redrock worked perfectly when the male threads of one ring "snugged up" into the female threads of the 82- 72 adapter ring. This was as reliable a system as the hard mount, but faster and easier to set-up, with what we found to be a better distance from the camera to the 35mm focusing screen for optimizing corner to center focusing.
Lenny levy
NSLL@pacbell.net
