Redrock M2 Cinema Lens Adapter 35mm w/Nikon Mount + Rig
chewdog316
Hello everyone-
I am selling my Redrock Micro M2 Gear. It has been amazing, but I am moving into a new career after college and no longer require it. :cry:
REDROCKMICROM2
If you are reading this you probably have heard or know a lot about this tool and let me tell you that it is great. With the addition of a PL mount you can even use the best glass around from Zeiss.
Here is whats listed:
Nikon Lens Mount
Nikon 28-70mm:3.5 Lens Mechanically 10 / Glass 10 / Casing 9
72mm HD Acromatic Lens
72mm Blue Coupler Ring
82-72mm Step-down Ring( to hard mount 82mm lenses to the Achromatic Lens)
72-55mm Step-down Ring( also hard mount piece )
55mm Spacer Rings ( look like filters )
Redrock 15mm Stainless Steel Iris Rods x2
Redrock Rod Support Base (Mounts to a tripod) Moderate Wear and Tear on base.
Quick Release Camera Plate
Set of Shims (Used to adjust camera height)
Set of Allen Screws
Full Set of Allen Keys (Used for Adjusting M2 and Shims)
Flash Light
Mini Screw Driver Kit
Hard Aluminum Case
It is all starting out at 99 cents. This item is great and is still very much a great tool to use. Get this while you can!! :shocked:
REDROCKMICROM2
Thanks for reading and buying. :2vrolijk_08:
