Complete Package includes:
M2 Cinema Lens Adapter
NEW 72mm HD Achromat (I have the old one too if you want it for some reason)
SLR Lens Mount
2 18" Stainless Steel Iris Rods
Support System
microFollow Focus
4 Lens Gears
3" Whip
12" Whip
18" Whip
Lens Support
microPowerPod
Redrock Hard Mount Kit, Shim Kit, and 82mm-72mm Step-Down ring
BRAND NEW - microMatteBox wide format shade (Literally still in the box)
-15mm swing-away arm
- 2 universal 360 degree rotating filter stages
- 2 dual-purpose filter trays, supporting 4x4 and 4x5.65" filter sizes
- wide screen interchangeable matte
- 4 rubber donuts
The microX image flip accessory (This is what flips the image upright, it's Awesome!)
- a new high performance optical achromat designed specifically for the microX,
- a riser block for adjusting your existing Redrock rod support system to the correct height,
- and a newly designed reinforced hard mount kit that also provides a "lock down" once your microX is correctly configured.
I'd give it all to you for $3,000 INCLUDING....
Lenses: Nikon 24mm f2.8, 50mm f1.4, 35mm-200mm f3.8
Package comes in Custom Cases
Also for sale: 8" IKAN HD monitor with case battery and charger - $600 (Bought for $900 including battery)
Shoulder mount & Handgrips: $60 (Bought for $95)
Give me an offer! Email for pictures or to come check it out.
lindsaymann@gmail.com
SLR Lens Mount
Support System
microFollow Focus
4 Lens Gears
3" Whip
12" Whip
18" Whip
Lens Support
microPowerPod
- 4 rubber donuts
