Ted Spencer
I just received a brand new Redrock Follow Focus today and set it up on my system. It was quite easy to do. However, I noticed immediately that there was a considerable amount of gear lash - both when simply turning the knob/gear in my hands and when fitted to the lens. Measured at the edge of the marking wheel, I see about 3mm of free play between rotational directions.
I should mention that this is only the second time I've used a FF. The other time was an IndiFocus (the updated version), and I don't recall feeling much play at all in the gears.
It's enough on this Redrock unit that critical focus is quite challenging, as there's a long "gap" to be covered between each direction of movement. It's also enough that the mark on the ring is only valid for one direction of movement. A mark made after focusing clockwise is quite inaccurate when focusing counter-clockwise, and vice-versa.
Being pretty inexperienced with these things (but again - seeming to recall that the Indifocus didn't do this), I'm not sure whether to conclude that the unit is not working properly or not.
I have read a great deal of praise for the RR FF, along with comments like "no play" and so forth. I'm certainly not finding that to be the case.
I'll have to wait until after the holiday weekend to do anything about it, but thought I'd post here for now to see if anyone might have some insight on the question.
Thanks!
(This was also posted on the forum at RR's site)
Thanks!
