RED idea: record at 35MB/sec
acrochordon
I heard that the Discovery Channel HD doesn't accept shows with a bit rate of less than 35MB/sec. If this is true (I didn't research that) then RED should be capable of recording at a bit rate be 35MB/sec. I don't know much about HD technical stuff. I am just now trying to learn. I don't have time to research stuff, because this contest is almost over. It is till the end of the month, right? Anyways, I post first and research latter. Sorry if my ideas make no sense at all. I am such a noobie. I looked at the RED website and they just list frame rates, Megapixes, and pulldown thingys like 4:4:4, (what ever that means.) They don't mention MB/sec as far as I can see.
You need the best data bitrate as you can record in order to manipulate larger amount of colour and luminocity. After editing and postproduction you can compress the material to any bitrate you want.
However, in the less important (requiring) projects this could be useful.
All the best for creative thinking, though.
Ah yes, the ever-marvelous 4:4:4 pulldown... very filmic! Seriously, 4:4:4 is the color space, meaning the colors are uncompressed. 35mbs refers to the delivery format, not the acquisition format. The RED will do both RAW (which is far more than 35mbs) and REDCODE, which is a wavelet based variable bit rate codec - also undoubtedly more than enough quality for the Discovery channel.
Anyway, you really should spend some time researching stuff instead of watering down this forum with really silly things you should already know... makes any decent ideas you may have look far less valuable if they are surrounded by dozens of nonsensical ideas.
