F FilmBoy77 Veteran Aug 5, 2008 #1 dumb question, if i wanted to use two boom ops with two of the same mics for wider coverage in a scene with multiple actors, am i only able to record to channel 1 and 2?
pranic Well-known member Aug 5, 2008 #2 You'll have to use channel 1 and 2 for the boom mics, while the 3rd and 4th will record the on-camera mic. If you want to mix both mics down to one channel, you'll need to use a field mixer.
T THoff Member With Answers Aug 5, 2008 #3 If the mikes aren't stereo mikes, the two XLR inputs are sufficient. You can map the XLR inputs to either channels 1 & 2, or 3 & 4.
