I'm onsite trying to figure out how to record via s-video from another camera. what setting do I need to change on the hvx to recieve it?
dunno..but will look through the manual unless someone else knows...
This is probably zero help to you (I don't own an HVX200), but since you seem to be active right now and no one has responded I'll share this:
I own an older Panasonic consumer camcorder and to record an incoming signal on it, I needed to be in "VCR" (playback) mode, and after changing some menu settings, had to use the remote to start the recording. No on-camera buttons would do it.
Sorry if that's zero help. If you have a projector then you can always try dimming the lights and filming that, I've had pretty decent results as long as I white balance properly.
That's pretty helpful. At least I know I was close. From what I can tell..camera has to be in MCR mode ( like you said VCR). AFter that, you can record onto TAPE, but not on p2. oh well.
