Don't you think 24p (that is 6 frames less then 30p) would be minor on the file size?
How 1920x1080 JPG picture per example would be the same file size then 1280x720p?
I think like the sony codec is a Variable Bit Rate, when you change 1080p to 720p the bit rate is a constant 35mbps and compression is better then 1080p.
But in the case of 24p I think 24p is really 29.97p and the file size would be the same.
Another question... 4:2:0 is it very bad compared to 4:2:2?
THANK YOU ALL!
THANK YOU ALL!
