SystemAgnostic
So I recorded a high school play. I'm using an LX100 for a wide angle shot, and a 70d with a 50-150 2.8 lens to zoom and pan during the performance. My question is: the lighting varies tremendously between scenes, and indeed within one scene they may walk into and then away from a brighter part of the stage. For one performance i was on full manual, and tried to adjust ISO as the scene changed. Unfortunately, I sometimes blew out some of the performers. For another perfomance I tried to use program mode and just adjust the exposure compensation. On the LX100 I was able to change to center weighted metering, I think I can't change 70d metering during movies? But unfortunately that didn't work for the LX100 because I needed to compensate more than -3 when the actors where in a black background. So I went back to full manual on the LX100.
So, are there any tricks or clues?
My best guess is that if the camera allows for enough exposure compensation (-5, maybe even more), I can use program mode and basically adjust based on the background, which is little less work than trying to adjust to every lighting change. An external monitor would also help so I can see the overexposure zebras better. And I need to remember to always underexpose when in any doubt.
