mainstreetprod
I'm shooting a feature on an HPX500. With 4 channels available, why would I need an external recorder and mixer? What are the advantages/drawbacks of this? (I realize this is not the way it's done, but I need a better reason!)
Also want to toss in how incredibly nice it is to not be tethered to sound (and vice versa). Syncing even with just a clapper isnt that difficult and doesnt take too much time. Now if you had timecode it would be even easier. Any time I have the option to shoot to a seperate recorder I always take it.
Less cables = happiness for me![]()
I plan on having someone else watch the levels
3. Without said high quality limiter or someone riding levels, you're in a very dangerous spot of clipping the audio which will then require ADR at a high cost to replace.
True, but I think someone riding levels will take care of this problem. I think levels being too high
is a lot more likely to happen with the preamp than without.
4. The levels get too low, resulting in the same thing.
That's one reason I just bought a 4073 boom mic as an alternative to the Oktava - much easier to achieve higher levels without a preamp.
5. No 24-bit audio resolution on the HPX500, which means it's even more important to have good levels going into the camera.
Just curious - how long has 24 bit been the standard in film production? This is a faith based film that may never get past the DVD stage. Howver, we recently had interest from a major distributor, which has me thinking about raising the bar a bit.
[/B]
You should still be sending a reference to camera whether its wirelessLess cables = happiness for everyone
Lets say I invested in a mic with an extremely good preamp section like the
AT 480B. Would the sound quality plugged straight into the HPX500 vs going through say an SD302 be that different? (putting aside for a minute concerns about clipping)
How does the mix pre compare with the 302?
Also, I already have a preamp designed for home recording studios (Studio projects VTB-1). If the specs were similar, could it fulfill the same purpose (as long as it doesn't need to be portable)?
Music preamps tend to have their own "color", that's why studios dedicated to music tend to have a variety of them. (The same holds true for music mics.) Tube pres tend to be more "colorful" as the tubes induce a certain amount of - usually pleasant - harmonic distortion. Manufacturers of production sound equipment try for a more "transparent" sound.From my experience, the music world and the production world are looking for very different things in a preamp. I really wouldn't recommend using that tube pre for production.
