I'm looking to buy some lights to add to my kit.
I have a few options already in mind depending on the type of light.
But looking for suggestions! :smile:
Fresnels:
No idea what's worth considering.
Thought about the Lupo Dual Colour lights, but I don't like how the control/LCD panel is on the side and not the rear. Other than that, I can't think of any other option.
I am seeing Dracast all over B&H, but there are no reviews anywhere. Not sure if these are any good in terms of intensity & colour.
Recommendations?
Panels:
Lupo Superpanel Dual Color 60 seems to be the best light as far as I can see. Aputure just announced one as well so I'm not sure how it'll compare as its the same size and will be the same price.
Having used the Arri Skypanel (s60 in comparison), this looks like a great cheaper alternative. The Lupo light is also a heck of a lot brighter.
I would probably consider the Lupo 30 (1x1) in the RGB version as that would also be for specialty purposes and I see no need in having one in the larger size as a bi-colour would probably be enough for most things. Unless it is worth getting RGB?
Flex Panel:
FalconEyes seems to be the best option; affordable, bright, and good TLCI rating. Compared to Litegear, its almost identical at about 1/4 of the price.
These lights I would probably use for more specialty purposes. Maybe when working in small environments or rigging it to a flat surface (car, against a wall, etc.) as the output isn't the strongest.
Fresnels:
Recommendations?
Panels:
Flex Panel:
