Recommendations for a Headset mic
Matthew B
I'm shooting a lot of yoga classes now, and am looking for some advice/recommendations on a headset/Madonna mic. I'm using a Sennheiser G3 wireless LAV at the moment and ideally would love something that can plug into that, but am also open to the idea of other systems should there be a better recommendation?
I'm looking for some advice on how to get to shoot a lot of yoga classes. :laugh:
Google search turned up this:
https://www.bhphotovideo.com/bnh/controller/home?O=&sku=1118995&gclid=COOxi7eXmdMCFU-4wAodPm4DbA&Q=&ap=y&m=Y&c3api=1876%2C%7Bcreative%7D%2C%7Bkeyword%7D&is=REG&A=details
and this:
https://www.bhphotovideo.com/bnh/controller/home?O=&sku=388644&gclid=CMjY55iXmdMCFQ4uaQodIecLwQ&is=REG&ap=y&m=Y&c3api=1876%2C%7Bcreative%7D%2C%7Bkeyword%7D&Q=&A=details
both are 3.5mm Locking Mini-Jack Connector, which I believe fits the G3 series.
The Countryman H6 is good for workouts and other activities with it's dual earpiece design, it's ain't low cost though. OST's HM-701 may be worth a look at for less $$$. Lots of others are available from Shure and the usual suspects. Most are available with the G2/3 locking connector.
Addendum: I would recommenced an omni directorial capsule, unless feedback from an integrated PA system is an issue.
Regarding the 1/8" plug; Sennheiser and Sony use different wiring configuration, so they are not cross-compatable, even though the plug is the same. I recall reading the new Rode GHz systems bodypack Tx is compatible with the G2/3 plug config.
I use Countryman headset mics. One thing I like is that they hold up well to sweat. But as Rick says, they aren't cheap...you could buy a couple OST and have a backup (or two) if the first fails).
And it becomes a style issue, but you could also look at something like a Countryman E2 Earset...that's a mic that extends just partly down the cheek. I've used those for some musical-theater and athlete stuff...taped down on the cheek to hold in place.
http://www.countryman.com/microphones/earset-microphone
Upsides: Sounds great, not visually intrusive, and stays in place as wearer moves around and bends, sweat not a big issue (in my experience).
Downside: Not cheap, talent needs to be OK with having mic taped to cheek.
Matthew, let us know what ends up working for you!
Don't know what a Madonna mic is. But it sounds like you mean earset and not headset. If that's true, the Countryman earsets are commonly used; they have models with Sennheiser termination IIRC.
Thanks for the suggestions. I looked at the countryman, but it didn't fit the budget at the moment. I ended up going with a Rode HS2, which I'll be using for a shoot next week.
